Light Bar
Installed the new Caliraised LED bumper 32" light bar, very happy, high quality, easy to install, and very bright.
My question is should I add the in grill model as well to really light up the ranch roads? Anyone out there have both? Do I need to add another battery?
One of my trail buddies has an overhead lightbar, winch and 32" lightbar similar to yours, he installed a larger battery and tray. His has been good to go with just the one battery.[/QUOTE]
https://caliraisedled.com/collectio...ota-tacoma-32-light-bar-lower-bumper-brackets
https://caliraisedled.com/collectio...ota-tacoma-hidden-grille-led-light-bar-mounts
Side question: Did you get the spot bar or the combo? I just ordered the spot bar and got confused when I had the option of a spot or combo. Ended up going spot as I figured the light would go further out in front. Curious if that is true?
I used the combo, for the bumper wanted to have the wider light and the distance as well. If I put the grill light in it will be the spot. I will put them on the same switch as well should be plenty of light
Which of the two are easier to install... Easy to install is important to me, as I always seem to have issues! Also, I'm just using for night driving on the road, so I figure the combo is better for me. Thoughts? I hope this doesn't interfere w/any sensors... as I do see on some light bars there are issues w/sensors. Thanks...
The lower one is harder but still do able though I have never installed one and was able to do it with no issues o did go with the rago fabraication kit since it was a better deal for the light bar a wanted. I went combo but just so you know these should only be used when no other cars are on the road or off road they are bright. This is mine KC light bar. PM me if you have any questions20181108_132817.jpeg20181108_132914.jpeg20181103_192133.jpeg
