2018 Tacoma TRD OffRoad Lift Options?
rp8
1. Like to get 3” lift front, 1 or 2” lift rear
2. Upgrade to bigger tires but keep existing 16” wheels
3. Keep existing shocks etc
What would you recommend?
Thanks
Update: based on suggestions
1. Don’t use spacers
2. Use Bilstein adjustable shocks like 5100 for front, but only 2” lift
3. Use AAL for rear
Question on Bilstein 5100 shock. Does it work with TRD Off-road stock springs?
Congrats on the off-road I like the color. Welcome to the forum.
Revtek Pro 40013 will give you that but will make the ride stiff. You could go 265/75/16 with stock wheels. You will need 1.25” wheel spacers to run any wider. With 1.25” wheel spacers you could do 285/75/16 tires. I had this set up on my off-road but I did MB TKO wheels at -6 offset. I don’t recommend wheel spacers and the revtek Pro is a in coil spacer which is not recommended by most.
[emoji106] x2
Haha
Low Range Offroad has a 3” / 2” kit for $240. Would love to hear from anyone who had it installed about any pros and cons. Thanks
For ~$475, you can get Bilstein 5100's with OME springs for the front and an add-a-leaf for the rear from Low Range offroad....
#FRIENDSDON'TLETFRIENDSRUNSPACERS
* on their wheels or in their lifts
Wouldn’t it replace my existing shocks? Mine has Bilstein shocks from factory.
The stock bilstein 4600’s aren’t anything to get to excited about. 5100’s are much better and adjustable.
+1
