2018 inferno red TRD Sport- lift kit/ tires ?
If your looking for a lift but not a huge lift, ReadyLift SST kits work great. They're kind of a leveling kit. Got 3" lift in the front and 2" lift in the back. I've got 17" Black KMC Machete wheels with - 38 offset and 3.5 backspacing. Also bought 2"Bora wheel spacers to give it a meaner looking stance and 285/75R17 (33's) Bf Goodrich A/T KO2 tires. The ReadyLift kit will cost you about $200-$250 plus labor. My tires I got done for $200 a wheel installed. That was the price of the tire and all the mounting and balancing and installation.
5100s all around with a AAL in the back.You'll thank me later for not sending you the spacer lift route.
If you're 2wd, you can use spindles up front for about 4 inches of lift. Then you need a leaf pack out back for lift.
Nothing wrong with blocks and spacers. You'll keep your original ride quality.
Spacers move the coilover down which causes it to bottom out internally before the control arm hit's the bump stop. This has caused many people to bend their shocks even on the road. Go too fast on a dip you don't see and boom.
Blocks add to axle wrap which is already an issue with Tacomas.
[emoji23]
But I saved money...
