2014 Tacoma led headlight bulb
Ok I just unscrewed the fan and put the factory rubber grommet on then screwed the fan back on.. We will see if it works and keeps out the moisture! I'm leaving my truck outside and will see in the morning.
Silverpataco everything worked good I have no moisture in my headlights after unscrewing the fan off and then replace the rubber grommet thx for the help!
did you adjust the beam cutoff with them to get a good cutoff pattern? that brand you can twist the bulb in the housing to get a good cutoff, I was looking at them for my truck. how is the camparison to the stock halogens as far as light projection hi/lo?
fwiw I put these in "SilverStar® ULTRA"
They really do help with night vision. Buy at Walmart and not Autozone.... way cheaper.
Hmmmm.
I wonder which are best. I'll spend the bucks to get the absolute brightest; its the best money you can spend if your night vision is going. I'll do some research because I've had these Silverstars for a bit and my last set went out after 6 months.... but Oreilly honored the one year warranty so the current set was free, but they still fall under the original purchase date so no more freebies.
