How big can I go on stock?
The biggest you can go on stock is 265/75/16, 265/70/17 which comes to 31.6”x10.4” so 32x11.5” is going to rub for sure. You’re more than an inch to wide and almost a half inch to tall. You could limit the rubbing with wheel spacers or a lower offset wheel and like birdslayer said modify the wheel wells where it’s rubbing either cut or heat and shape. If you always drive straight and never hit a bump you’ll be ok. In the end you’ll still be rubbing under any flex and lock.
Shake weight...
