OBD2 Bluetooth Scanner
Bogunn
I just picked up a Veepeak Bluetooth OBD2 scanner. It’s a pretty good little implement to have. It gives real-time data monitoring and diagnostics plus you can still clear codes like a regular OBD2 scanner.
I’ve had a scanner for years but with the BLE Scanners you’re only as limited as the app you use. It’s really worth paying $30+/- for.
Link?
Q: When i plug it in, my abs flashed on the dash. it turns off when i remove the scan tool. what should i do? i have an 2003 toyota mr spyder. see less
Answer this question
A: Do you have good looking abs? if so leave it plugged in when you have a lady in the car:)
Also, the DashCommand and OBD Fusion apps have a ton of options when using a OBD2 scanner. Really worth looking into.
Blue driver Obd2 Amazon, Bluetooth 4.0 for IOS & Android , 29.99 ! I put mine in , it works great , saves us from the Stealer Dealers ....
My order for this scanner has been shipped and should arrive this week.
I have NOT figured out which app to get for my iPhone 8. Your two suggestions have lots of features. Any preference for one or the other ? Any of the others at the App store spark your interest? This is the first device of this kind for me so I'm venturing into the unknown... 2017 Tacoma TRDOR Tech & Prem Audio Pkg...
Thanks for the help...
I like OBD Fusion after using it for a while. It is more user friendly and has a lot of options.
