Body lift?
terese
Should I put on a 3 inch body lift with the blocks? Will the ride be smooth? Is there any disadvantages of doing a body lift instead of a suspension lift?
Body lifts put more leverage on the mounts, you have to extend the steering shaft and possibly wiring and they generally look like garbage. Ride will be stock because the suspension is stock.
Spend good money on a lift once.
Oh man. Stick with C load range tires and they won't get too heavy. What's the best lift height? That's really on what you want. 6 inch lifts usually require cutting of the front cross member to which is a no no in my book. If you are a prerunner you can run spindles up front instead of a drop bracket lift.
No body lift. What year and model Tacoma do you have? SR5, off-road, sport? 4x4? 2wd?
