Brakes
If there's question you can pull the front wheels off and do a visual......rear ones pull the rear rotors and visual also.
Yes sir I knew that but I’m not physically able to do that due to heart and back surgery. I was planning on taking to my mechanic however I very seldom drive it.
Thank You
With only 37000 miles I wouldn't think you need new breaks. Sometimes the rotors will get a thin layer of rust sitting over night. When you first apply the breaks the pads will scrape the rust off and that could be your squeal.
If you are able, take a look through the wheel and you should be able to see the rotor. Have a quick look before you move the truck.
