So did width and length change with 2024 Model?
NoRecalls
I not reading anything about dimension changes, so assume 2024 measurements are the same at 2023? Bummer though that Toyota is not coming out with prices until end of year and next year for TRD Sport. Wonder why the pricing delay>
TRD Pro has a 3" wider track (distance between the centerline of the wheels on the same axle), but it looks like exterior dimensions look similar, probably within an inch or so. I don't know if it is just the styling, but width looks a little larger, as does height.
The height is likely different due to a different suspension calibration. Idk why the actual wheel base would be.
Yes height I believe was changed. Seats also raised one inch. I'm seeing 213.3 for length and 74.4 for width. And I talking TRD Sport and not Pro or Limited which might of grown a little bigger. Surprised Specs/measurements are not out, but maybe that's due to no change from 2023.
