JayQQ97
MW surVivor ... clutched. 366k on the 0D0
The oil drain bolt comes stock with dark gray fiber washer. Your suppose to use a new blue washer when every time the oil is changed. I've seen issue's with oil leaking afterwards from the drain bolt because some guys don't clean the old washer surface off well enough before installing the new blue washer. Imo, its best to leave the old washer on. I've never seen one leak.
ok i will ask you a direct ?
do you dunk the new (or reused) fiber washer into motor oil before securing between bolt and pan
or do you put it (the fiber washer) on DRY?
word of weirdness...
the dealershop in Maine I had the oil changed in May used some plastic washer
