Taco_Rob_19
Hi!! I have read most of the lift threads on the forum and was wondering if anyone has lifted a long bed with or without a cap? I’m looking at going with the Headstrong Bilstein 5100 kit with the HD Dakar springs. I wanted to keep the front between 2 1/4-2 1/2 inches of lift. I wanted to know what people’s experiences were with the different rate OME springs and how much they settle after the first couple thousand miles. Also what are people doing for diff drops, carrier bearing drops and rear axle shims? I read a few threads about measuring the drive line angles to figure out everything before and after and I do understand the whole within factory spec. Also will I be able to run the factory wheels and tires for a while without rubbing? Thanks in advance and any other info would be appreciated!!!
