Screw the shovel, I got a 70's tractor with a blower on it hooked up to pto. That sucker with make short work of 3' high snowfalls. Every time I use it after a storm, it strikes fear in other neighbors.You do know the snow shovel is the mowers demented cousin.
no rotation of tires?
Well ****. That ain’t good.pink coolant drop drain fill burp day on Gen2 here
It's good when I get Toyota pink for about 15$ a gallon deliveredWell ****. That ain’t good.
Nice and you got 3 pedals too?What did you do with your Taco today
I've been lazy and haven't kept up with a clean cab so today I had it professionally detailed. So much better.![]()
Mine did the same when I was under changing the oil the drivers side is already gone? On the side of the road somewhere so I took off the other one .Did find a source of a rattle. Heat shield escaped one of its mounts. Need to find a small ID fender washer.
I hate them stupid things. They always seem to fail in the most inaccessible spot.
This one is on the heat shield passenger side above the 2ndry CAT, near a frame cross member and the transmission.
