2007, 4X4, manual, 4.0 L, clutch.
crowgsxr
Hello All,
I am new to the forum and I need some advice. I have a 2007, 4.0 liter, V6, 4X4 Taco. It only has about 56,000 miles. The clutch pedal started not returning after depressing it, and now the gears are not going in as smooth. I have not felt any slipping when it is in gear. Is it too soon with the low miles to be needing a new clutch? I wish I was as mechanically savvy as most of y'all. Any assistance will be greatly appreciated.
Thank you,
Crow
That’s very low mileage for a clutch to fail, unless it was abused.
Have you checked your hydraulic clutch fluid level? It sounds more like a peddle issue than a clutch problem. Check for fluid leaks.
