1. Hello everyone I recently got a 2018 SR5 and got an K&N Air Intake installed. I have noticed every once in a while my low oil pressure light comes on only for a second or two then it turns off was wondering if anyone else had this same issue. The truck is running completely fine I haven't had any issues with it at all. Thanks for the help.
  3. B-Man
    B-Man Well-Known Member
    Welcome to the forum! No info on the oil light.....my '17 OR is workin' well!
  4. Bogunn
    Welcome to the forum. Did you check your oil level?
    OR17TRD likes this.
  5. Crawdad
    Crawdad Well-Known Member
    This was my first question as well.
    OR17TRD and Bogunn like this.
  6. OR17TRD
    Good start.
    Bogunn likes this.
  7. OP
    Carlos Aragon III
    Carlos Aragon III Member
    I have checked my oil and it is good. Like I said light only comes on for a second or two then goes away
  8. OR17TRD
    Does it come one when you first start the truck or just randomly as you’re driving?
    kp.taco likes this.
  9. kp.taco
    kp.taco Well-Known Member
    If the oil light is coming on while driving and the oil level is good it needs to be takin to dealer ASAP . Could be an issue with the oil pump
    Bogunn and OR17TRD like this.
  10. OP
    Carlos Aragon III
    It doesn't come on while Im driving usually only see it when I am changing from Drive to Reverse or if the truck is idling
  11. Bogunn
    Did you run an OBD2 to see if it’s throwing any codes? It’s an off chance if it’s not staying on but worth a shot.
    I’d take it to the dealership personally since it’s under warranty.
    Scott Wyman and OR17TRD like this.
  12. OR17TRD
    Dealer trip
    Scott Wyman and Bogunn like this.
  13. Scott Wyman
    Scott Wyman Well-Known Member
    Ditto
    OR17TRD likes this.
