Engine swapped Tacoma?
Discussion in '2016 + Toyota Tacoma' started by DylanS, Dec 4, 2019.
  1. DylanS
    DylanS New Member
    Need help!
  3. OP
    DylanS
    DylanS New Member
    Is it possible to swap my 3.5 v6 with a 4.0 v8?
  4. Bojangles
    Bojangles Well-Known Member
    Sure if u can find a 4.0 v8 and have the money or skills.
    Nothing is impossible
    Scott Wyman likes this.
  5. Bojangles
    Check your local laws
  6. whippersnapper02
    You'd basically need the complete wiring with ECU for the V8. Nothing easy. It would be cheaper to just get forced induction on your current engine.
    TacoNorth, Scott Wyman and Bojangles like this.
  7. 88e30m50
    88e30m50 Active Member
    You’ll also need to look into the transmission to see if it will mate up to the new engine. If it does, will you have to modify the driveshaft if the swap puts the engine in a slightly different spot. Are your axles and transfer case rated for the load that the V8 brings? If not, there be more work there.
  8. Taco4x4
    Taco4x4 Member
    This would cost so much I can't imagine it's worth it. I know a guy did a diesel swap for $30k.
  9. Tape
    Tape Well-Known Member
    Buy a Tundra, a v8 Tacoma would be SWEET
  10. TacoNorth
    TacoNorth Member
    There was a time when swapping out engines wasn't too hard. Of course, in those days there was room to spare under the hood and the main concerns were motor mounts and mating the engine to the tranny (not to mention finding out if the suspension will hold up the added weight). You still have those concerns plus (as previously stated) the engine control unit (ECU or brain) has to come along with the new unit, finding out if the fuel system can handle 2 more cylinders, figuring out if the driveline (rear+front if it's 4x4) will handle the added torque, etc, etc, etc. If all that doesn't slow you down then (also, previously stated) anything can be done for the right price. Good luck.
    Bojangles and Scott Wyman like this.
