Flash module?
For what year tacoma?
Do you need one because you switched to leds and they flash too fast now?
Did it burn out/fail?
Or need a heavy duty flasher for a trailer with many lights?
What model i search for to help you, depends upon your needs.
It’s a 2019. Something like the Speed Turtle 2.0 from ultrabrightlights. I cant post the link....
Just to make all the lights flash in patterns. Thinking it’d be an easier mod for flashing/emergency lights vs installing a light setup. Thanks!
Flash in a pattern?
I must admit ignorance here.
Sorry
Correct. You’re fine. It’s really a cool piece. It plugs into the OBD port and when you turn your flashers on it makes all the factory lights flash in different patterns. I haven’t found anything like it for tacomas.
Neither have i.
I thought you just needed a regular relay.
I put heavy duty ones in my pickups shortly after buying them, because I tow a lot, and some seem to struggle with the signal lights when a trailer is plugged in.
This was 20 years ago, but it is a habit now, so i just do it anyway.
