Help!..Leveling kit for 01 sr5
Discussion in 'Aftermarket Products, Reviews & Installation' started by Fred.89, May 8, 2016.
  1. Fred.89
    Fred.89 Member
    Hey guys anyone recommend a good leveling kit? I looked around for a few so many choices!
    I'm digging sky jacker so far. But my main question is what all do I need to level my 01 tacoma sr5 to not wear anything out or put stress on other parts.
  3. kingkillah808
    kingkillah808 Member
    Get coil overs, way better in the long run, unless your not really offloading and going more for the look. Used a daystar leveling kit on my 03 pretty runner, no problem just make sure to get alignment after installing
    Fred.89 likes this.
  4. OP
    Fred.89
    Fred.89 Member
    Little bit of both the look and some offroading. Did you only add coilovers no other upgrades on suspension or sway bars?
  5. PinkTaco
    PinkTaco Well-Known Member
    Ome or toytec
    johng813 and Fred.89 like this.
  6. OP
    Fred.89
    Fred.89 Member
    badass site for parts!!! thanks pink taco.
  7. PinkTaco
    You checked out toyteclifts.com ?
    cope45 likes this.
  8. OP
    Fred.89
    Fred.89 Member
    toytec the ome went straight to it aswell
    PinkTaco likes this.
  9. rogerry
    rogerry Well-Known Member
    Bilstein 1500s can level your truck, although they will preload the coil (depending on how much you raise the front) so making the ride a bit stiff yet still comfortable. Another method is using readylift leveling systems. They cost a bit more compared to other leveling kits but they guarantee to maintain stock ride quality.
