Longer rear shocks
You won't need new shocks, but you'll probably want to get a driveline spacer to account for the angle
Wait for it...
I've got 2.75" rear OME Dakar springs and 2" blocks under them with no drive line vibrations! Had 3" longer rear spring on my FJ with 1.5" spacer on top put 188,000 on it in three and a half years no drop down spacer on it either! 4.75" on the Taco and 4.5" FJ no issues.
How about longer u bolts for the aal? The kit didn't come with any and I'm not sure if the stock ones will work?
Measure the spring thickness your adding . Then see how much thread is left on the bolts! If you've got more thread then spring your all set!
