JayQQ97
MW surVivor ... clutched. 351k on the 0D0
Hi All
was alerted to the transmission possibly weeping at the transfer case
wiggled underneath the rig and found some definite pooling in a few spots
checked the levels of both gear boxes and found the level to be full and perhaps a bit overfull with the amount that came out of the check plug on level ground
but i had just gotten back from a hot wheel in the wind so it was still warm gear oil in there
if it all matters what temp it should be for a proper check since that fluid likely expands when heated
...will need to keep an eye out on this
