Spark knock
Assuming your diagnosis is correct......suggest you take it to the dealer. Describe the symptoms and conditions when the symptoms manifest.
Let the mechanics do their work to isolate the problem.
Engine control systems are not a good place for the Backyard DIYer to be playing in. Good way to push the truck into FUBAR land.
FWIW, spark does not knock. Pre-detonation of the fuel is the source of knock. If you are correct, then something is not quite right. Knock typically only manifests when the engine is under load, while downshifting the engine is not loaded.
