Spark plugs
Discussion in 'Maintenance' started by dwayne.surrat, Aug 27, 2018.
  1. dwayne.surrat
    dwayne.surrat Well-Known Member
    I have a 2010 Tacoma with a 4.0 and I have about 149,000 miles. I have never changed the spark plugs. The truck is running good. I seen a thing where it says you should change the plugs about every 30,000 miles. So do you think I should change the plugs now or wait till I have a miss.
  3. whippersnapper02
    I'd change them now. They are pretty inexpensive.
  4. OR17TRD
    I hope you aren’t the original owner. If you don’t know when it’s been done last you can always pull some and check them. See how they look.
    TacoBOB77 likes this.
  5. OP
    dwayne.surrat
    I got the truck with around 18,000 miles so I’m sure they are the first set
    OR17TRD likes this.
  6. OR17TRD
    I’m shocked it’s not missing and the fact that its running ok is amazing.
  7. OR17TRD
  8. OR17TRD
    What you’re not telling us is your wife took it in for its 90 and 120k mile services o_O
  9. OP
    dwayne.surrat
    Not married and I’m the only person who drives it.
    OR17TRD likes this.
  10. OR17TRD
    Additives? Jet fuel? Special gas station you always go to? How they are still clean enough to run is blowing my mind. 150k miles on a set of Plugs with no issues is a lot. I want pictures of them when you pull them out.
    TacoBOB77, Crawdad and dwayne.surrat like this.
  11. Bogunn
  12. kp.taco
    kp.taco Well-Known Member
    Yes. Please post pics I wanna see these suckers too..
    OR17TRD likes this.
  13. Crawdad
    Crawdad Well-Known Member
    = 2.5
    B-Man, Bogunn and OR17TRD like this.
  14. OR17TRD
    You’re so good at math.
  15. Crawdad
    B-Man, kp.taco and OR17TRD like this.
  16. AZ Pete
    AZ Pete Well-Known Member
    iridium plugs have a service life of about 100,000 miles. I expect that the OEM plugs in your 4.0 are Denso iridium plugs, so that or NGK iridium plugs should be considered as replacements. I have changes several sets of iridium plugs, at the recommended 100,000 to 105,000 mile mark....they all looked to have no noticeable wear.
    RonFad and TacoBOB77 like this.
  17. Crawdad
    Couldn't help it, it was a reflex, just finished 2 chapters of HW and a test this morning.
    TacoBOB77, Bogunn and OR17TRD like this.
  18. whippersnapper02
    They are standard copper plugs from the factory. The poopercharger kit includes iridium plugs because you have to remove the blower to get at the driver side plugs.
    TacoBOB77 and OR17TRD like this.
  19. OR17TRD
    I don’t think toyota uses the iridium plugs in the Tacoma for OEM. They are usually platinum which last about 30k or so. I could be wrong on this one.
  20. Bogunn
    Yay. Good for you improving your math.
    B-Man and OR17TRD like this.
  21. AZ Pete
    may not, but that is what my neighbor's Tacoma 4.0 had when I changed his. They were in my wife's 03 Camry, and my 08 Tundra as well. Maybe we were just lucky.
