Full catback exhaust? Did u unplug any oxygen sensors?Do I need to reset my computer ?
Are you having issues or are you just curious? Should be good to go as long as you didn't cut any wires in the process somehow... 0_oYes. And no
What would the need to do that be? Thought process? Idea?Do I need to reset my computer ?
Is this ritoricle?[emoji848][emoji23]What would the need to do that be? Thought process? Idea?
I just want to know if he read something somewhere that said it would help reset the ECU to help in some way.Is this ritoricle?[emoji848][emoji23]
I would say run it see how it act's if it ain't broke don't fix itYes. And no
Words to live by.I would say run it see how it act's if it ain't broke don't fix it
NoDo I need to reset my computer ?
I replaced my manifolds for headers, replaced ypipe, threw on a 3" catback, all new 02 sensors, and didn't do a thing to the battery.Full catback exhaust? Did u unplug any oxygen sensors?
No kaboom, no idle issues.
I've also swapped different headers around without touching the battery.... No issues, afr reremained at 14.7:1 at idle immediately upon starting the truck.
U just want me to be stuck resetting my clock and stereoMaybe you need to reset your computer....
I put new lugnuts on recently too... I better recalibrated the speedometer
Absolutely. You may have to put a new modulator valve in the flux capacitor too. The manual recommends changing it every time you recalibrate the speedometer.
It has dual modulator valves, one ngk and one denso. I can't afford this, I just caved into my caffiene needs and bought the apple of coffee makers today. Damnit Amazon.
I feel I'm going faster than everyone else at same speed is that from a bigger tires or do I need to recaliberate?U just want me to be stuck resetting my clock and stereo
I think at 60 mph you're going 64 with 285/70-17... that's real close if not right. I've never recalibrated, just kinda keep it in mind.I feel I'm going faster than everyone else at same speed is that from a bigger tires or do I need to recaliberate?
Use GPS to compare ur speedI feel I'm going faster than everyone else at same speed is that from a bigger tires or do I need to recaliberate?
