I have a video but can’t seem to post it
IMO Thats normal, much quieter with the hood down, Quit trying to "Listen" so hard.
Welcome to the site
Unless your engine is pinging, premium gas is just burning unnecessary money. These trucks were built to run on regular, the higher octane just makes the flash point temp higher to help prevent pre ignition. If it runs fine on regular there is absolutely no benefit running premium gas. Here is a quote from a mechanics forum,You aren't the first to complain about ticking. I really don't have the answer because mine don't tick. I know the injectors go thru a cleaning cycle ocassionaly but it wouldn't be every time, and I haven't heard my injectors cleaning yet so I don't know if that would be a noticable noise anyways. Beings the noise is in drive at idle and not neutral id say it would be related to oil pressure because youre engine will idle a little faster in neutral than in drive. I run Amsoil and premium gas and mine has always been quiet. Is that the answer, I really don't know. Amsoil, mobil1, castrol appear to be the most popular oils around here and been hearing good things about the Rotella gas truck oil. Someone else had reported that their engine quieted down with premium gas. I don't know if any of this will help youre situation, its just what I do.
The last paragraph says it all. They 3.5 is a 13 to 1 engine and yes due to knock sensors and host of other computer stuff can run on 87 octane gas however performance and driveability suffers.Unless your engine is pinging, premium gas is just burning unnecessary money. These trucks were built to run on regular, the higher octane just makes the flash point temp higher to help prevent pre ignition. If it runs fine on regular there is absolutely no benefit running premium gas. Here is a quote from a mechanics forum,
“Here's the deal : higher octane means less volatility, and this is meant for engines with higher compression so that the fuel doesn't ignite too early in the cycle . Lower octane fuel is more volatile and is meant for engines where compression rates are lower, so that the ignition in the cycle not occur too early .
In all cases, follow the manufacturer's octane recommendation for better performance . However most cars which use high octane are able to accept regular gas because they are equipped with knock sensors which will automatically adjust the engine cycle timing, thus reducing engine knock or detonation. Engine performance will be diminished however.“
Not my engine if i run only 87 octane fuel. It runs worse with anything higher. I noticed less power on hills, and worse fuel economy. If they designed these engines to run best on premium toyota would of stated so. Instead its 87.The last paragraph says it all. They 3.5 is a 13 to 1 engine and yes due to knock sensors and host of other computer stuff can run on 87 octane gas however performance and driveability suffers.
If you read you're owners manual it says that 87 octane is minimum octane, not that 87 is recommended or preferred, it says 87 or better. But since you know and are satisfied with youres go ahead and run 87, it's you're truck.Not my engine if i run only 87 octane fuel. It runs worse with anything higher. I noticed less power on hills, and worse fuel economy. If they designed these engines to run best on premium toyota would of stated so. Instead its 87.
