spursnation2323
What kind of tires? And size?
265-75-16
Hey! Yes thank you for the advice, i appreciate it! Now i just have to educate myself about lifts and suspensions. Thanks again brothaWelcome to the forum ! I put 17x9's on my 16 sport and wish I did 8's it would have given the sidewall more bulge,and there is not as many tire choices in 17 as 16 s IMO.I also had to lift 1.5 inches to get front clearances. With the 8 inch maybe not . Hope this helps .
View attachment 31447 My rims are 4.5 backspace and -12 offset .
Hey Wex, did you have any problems with the Pro Comps rubbing on the brake calipers? I’m looking at that same wheel, but am hearing there might be some rubbing (brake calipers, not tires). Very nice looking truck by the way.View attachment 8469
265/75/16 is the biggest you can go with no lift/trimming/rubbing according to Discount Tire.
I have Pro Comp 7032 16x8 4.5 backspace/0 offset with BFG T/A KO2 265/75/16. They stick out about 1-1 1/2" more than stock and don't rub at all
View attachment 8470View attachment 8471
16' TRD Off Road DCLB Inferno
Hey everyone, I didn’t want to start a new topic so thought I would ask here. I have a 2021 SR. I purchased the replica TRD pro wheels. These are 17x8 with a +15 offset. The tires I am going with are Falken Wild Peaks 265/70/17. There are no mudflaps on the SR.
Will I have any issues with rubbing? Thanks for your input!
Should be fine. I have a TRDOR stock with 265/75R16s with no problems. 265/70 came on them factory.
