JayQQ97
how do you know if leaf springs are shot?
the AdvanceAutoParts (AAP) directed me to look into this and why the rough ride on trashed broken roads did not dissipate much after putting in the new Monroe quikStruts in the front. I still need to replace the Toyota rear shocks with the KYB brand i bot last month, maybe those will make a difference but IDK
another thing i have been noticing is when i jacked up the truck at the transmission crossmember area to check the front driver wheel wobble and bad bearing, when i lowered the truck it looked like it had a 3" lift where it would not settle down to normal stock height... big gap in the wheel housing area in the front... what might cause this and the remedy for it
