Probably being converted to electric....either that or moonshine. At any rate i'll likely be fertilizer by then so it won't matter.How do you see yer truck doing in the year 2045?
When there's salt on my roads, maybe twice a year, I drive the AWD or FWD vehicle and leave the RWD trucks home. I prefer controlled fishtailing instead of RWD on ice fishtailing.If yer taco ain't seen winter salt then you ain't livin it up![]()
Embarrasingly NO. Fords. In my defense I am looking for a Toyota SUV so I can sell the turbo Ford SUV. Nothing wrong with the Fords but I just feel dirty when I drive them. I have a very very very very long history of owning both Toyota and Ford vehicles. Had good luck with both. Since I am blabbing my dirty secrets I must confess that I had a passion for LT1 Z28's for a few years too (while still owning a Toyota and a Ford). Guess I am just a skank when it comes to vehicles. A two-timer or a car-gigilo if you will.You have the Prerunner?
Those rims look nicer on a truck than a 4runner!I did treat my Tacoma to a new matching spare wheel and tire today. Now, since the 2008 has a tpms in the spare, I can do 5 tire rotations.View attachment 34672
My OEM 17" wheels had peeling and extensive surface corrosion. I did the refurb and paint. Its a lot of work to strip the OEM coating to the aluminum. I tried chemical strippers......didn't phase the coating. Ended up, after several trials, using a series of wire wheels on a small angle grinder. The stripping took roughly 5-6 hours per wheel. Prep for paint was about 1 hour per wheel.i'd like the oem yota wheels on my rig refinished (abrasions and mildish corrosion), alloy wheel repair was estimated around 700$ a couple years ago
other pricey repairs and maintenance have been needed, however...
still waiting for the yota warehouse dealers to clearance markdown the new OEM wheels more, they are STILL +400$ eachMSRP 583$
4261104041 - Toyota Wheel (Front, Rear). DISC; DISC (FOR FRONT) | Lewis Toyota, Topeka KS
Genuine Toyota Part # 4261104041 (42611-04041) - Wheel (Front, Rear). DISC; DISC (FOR FRONT); DISC (FOR REAR). Fits 4Runner, Tacoma. Ships from Lewis Toyota, Topeka KSparts.lewistoyota.com
Usually those japanese manufactures do just the opposite...as their inventory dwindles, the price on the part goes up. They figure if you want it bad enough, you'll pay their price.i'd like the oem yota wheels on my rig refinished (abrasions and mildish corrosion), alloy wheel repair was estimated around 700$ a couple years ago
It's too bad these used 15" used salvaged mucked up worse than mine are dime a dozen out there!Usually those japanese manufactures do just the opposite...as their inventory dwindles, the price on the part goes up. They figure if you want it bad enough, you'll pay their price.
Knda depends on how well the owner maintains them.i wonder how long the Gen2 steelies will survive before looking like rubbish!
I suppose the salt sitting upon eats right thru the coating!Knda depends on how well the owner maintains them.
Use rim weights, leave 'em dirty, ignore chips, bang against curbs...... You can expect short life.
Take care with basic maintenance and they will last.
