JayQQ97
MW surVivor ... clutched. 366k on the 0D0
page eleven...
12-10-22
50, it has arrived...
OMG, John! this is No No good!
www.tacomaworld.com
"Well, now I have bigger problems, when they were replaced 130,000 miles ago red lock tight was used and the dam 4 bolt heads now are just getting stripped off, they won’t budge with a socket or wrench, the heads are just rounding off, that bolt metal definitely is NOT very strong
So much for lock tight,
uggg"
red lockTite on LBJs
yiikes
www.tacomaworld.com
www.tacomaworld.com
www.tacomaworld.com
www.tacomaworld.com
www.tacomaworld.com
those OEM shock mounts are now MSRP of 124$ ... up from 110$ on that quote
86$ on the 31 per cent 0FF deal
12-10-22
Can LBJs fail without any warning ?
So for 1997 without the dust cover 4x4 with OEM BLACK bolts the 4 bottom bolts should be 37lbs and NOT 59lbs? If you have the dust protectors, then...
uggg"
yiikes
Spark plug tubes rust
What's the solution to addressing surface rust on the inside spark tubes, grease,? To stop it? [ATTACH] [ATTACH]
Gas light level
I am pretty sure my truck doesn’t have one but how does one tell besides looking for the light to come on? This is my fuel pump when I replaced it last...
Steering rack clamp bushing movement?
is it normal to have rubber residue on either sides of this clamp bushing? The rack and bushings were all replaced 4 years ago OEM? Does this part of...
1997tacomav6
1997tacomav6 is a V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k at Tacoma World
4860935010 - Toyota Suspension Shock Absorber Mount (Left, Right | Lewis Toyota, Topeka KS
Genuine Toyota Part # 4860935010 (48609-35010) - Suspension Shock Absorber Mount (Left, Right, Front). FRONT SUSPENSION, LEFT; FRONT SUSPENSION, RIGHT. Fits Tacoma. Ships from Lewis Toyota, Topeka KS
parts.lewistoyota.com
