Squealing is usually a throwout bearing going tapioca.Still it is squeaking
Perhaps at the pivot?
As far as seeing the clutch fork, and bearing....even blown up, you can hardly make it out, let alone any defects.
This is itThere is a removable plate in the front there
Looks like a semicircle from Timmy toolman uTubes
to check the rear main seal for weeping?Its likely an inspection cover.
Update: solved!
finally ended up taking it to the shop. They were just as stumped as me, master and slave were fine, line was bled fine. But still sometimes pedal, sometimes not. They continued to bleed it thinking maybe there’s a stubborn air pocket somewhere in the line. While bleeding it the clutch fork broke. Said it was either bent or cracked (probably bent) and it wasn’t getting enough travel to engage the clutch, which makes sense because it looked fine from the outside but I couldn’t see inside the bell housing where the problem was. Mechanic said he’s never seen one break. I just feel vindicated at least that it’s not something I could’ve diagnosed on my own because I’m not qualified to drop my transmission or take it apart. Sucks that the labor will be expensive because the transmission has to come out to replace the fork but all in all just happy I didn’t mess something up. Thanks everyone for your help and suggestions.
