JayQQ97
to maintain climb speed on the hilly this procedure is always having to be done since no feathering on the throttle will kick it down to 3rd to get rippin' up the hilly for safety
otherwise it just bogs down losing speed can be dangerous AF
? will the continuous need to operate this Gen2 AT 4cyl in this manner put undue stressors + wear on the internal transmissions parts
or will it just be normal wear?
RPMs jump from perhaps 1500k at bogdown to a bit over 3000 RPM
i will suppose the AT REVMatch this to the engine and synchronizes all of it for proper operations
is this correct or is it not correct
transmission currently has 84k and change
and has had two T-IV drain and fill of ATF so far
