18-Nov-2o23
this here perhaps is the genuine solution
TOYOTA TACOMATRN240L-TRPDKA - BODY - FRAME | Japan Parts EU
TOYOTA TACOMATRN240L-TRPDKA , FRAMEwww.japan-parts.eu
79$![]()
Front Suspension Member Brace Sub-Assembly Right Hand #51403-04020 | Autoparts.toyota.com
Boost your Toyota's stability and ride comfort with our Front Suspension Member Brace Sub-Assembly Right Hand. Genuine, optimal fit, and backed by a warranty.autoparts.lewistoyota.com
91$![]()
Front Suspension Member Brace Sub-Assembly Left Hand #51404-04020 | Autoparts.toyota.com
Boost your Toyota's stability and ride comfort with our Front Suspension Member Brace Sub-Assembly Left Hand. Genuine, optimal fit, and backed by a warranty.autoparts.lewistoyota.com
this may be a cause of dissimilar metal rott but IDKHi!))
It sounds like the nuts should be welded to the frame to hold the bolts. If they keep spinning, you might need to get a welder to fix them or find an alternative fastening solution. Double-check the diagram and consult your dealer for precise information. Good luck with the repair!
Maybe red if I were living in east LA, otherwise black is fine.red for red taco adds razzle dazzle ??
where the sun do NOT shine upon
