Depends on your need the factory tires are considered standard load and are not on the alphabet scale of load rating. SL tires will be your lightest option but not alot of aggressive tread at tires come in sl so you go to the lt rating on the alphabet scale my duratracs came in c or e for the size I got the c is already a much higher weight capacity than stock and 2 pounds lighter than the exact same tire in an e rating that has even more weight capacity. In the stock tire size bf Goodrich makes a ko2  in a d that weighs 49lbs and that is the lowest for that tire and weighs more than my larger duratrac with a c rating. Even without going to a bigger tire you can increase tire weight thus reducing mpg. If mpg is your top concern stick to the SL tires but it limits your selection to the more street oriented side of the at tires
