I agree 100% that the 5 speed with the 4.0 liter is a much better drivetrain than the current. The Atkinson cycle 3.5 hasn’t had a chance to prove it’s strength and longevity yet so I can’t make a solid judgement on it.
The transmission is the problem with the current drivetrain and it’s the shift points that seem to be the main issue.
I have a Mopar with a 9 speed tranny and a 3.2 liter 6 cylinder. It runs as smooth as anything I’ve owned and shifts seamlessly while getting 27-28mpg. It isn’t the amount of gears, it’s the shift points.
I want more revers gearsYou do realize we're talking about the same thing basically , my contention is with the somewhat narrow power band of the v6 it's naive to expect a 6 speed auto to behave "normally" , now you mention shift points , by way of ECT (or similar, doesn't even have to be a toyota) What that does is change duration (lengthen) between shifts, assuming it's taking out (overriding) auto OD giving any available USEABLE power within the band (rpm-/+) so that particular gear can squeeze all useable power within that band (again) until it's ready to upshift again (which it's doubtful it will unless foot is off the gas) ,,,
Which brings us to this point, by using an ECT system (or similar) you've taken away from transmission programing it's auto-detect load/rpm/throttle pos. that tells it to hunt around playing musical chairs with ALL the gears. It kinda contradicts it's self with the "more gears the better", if this were true, why does it have to take out 3 speeds in order to operate "normal" under a "normal load"
Translation, the 6 speed auto has to return it's self to older 4-5 speed autos to do the same job they were already doing, thats the thing, rarely heard any bitching about early 2nd gen trans, auto or manual....
IMO only large diesels need multi speed transmissions (in excess of 5 forward gears)...
How many words do we need to use to say the turd gen tranny blows shifting sticks?Yes I do realize we’re talking about the same thing basically. Lol. I was pretty much agreeing with you in an extended post.
But sadly since we are stuck with the emission criteria and forcibly programmed low shift points the more forward gears the better. It’s crazy to have 9 forward gears to do what 5 or even 4 can do. But it is what it is. With the way things are you can get up to speed more efficiently with lower shift points and better mileage with more forward gears.
Toyota screwed up by throwing a 6 speed in a truck with ridiculously low shift settings. Basically forcing the driver to put their foot in it or turn on ECT to do what it should have already been doing to begin with.
If they had thrown a 9 speed automatic in (or programmed better shift points) there wouldn’t even be posts about this on any forum.
It all boils down to EPA regs that are ridiculous and the battle to squeeze more MPG out so they can compete for “best in class” over the other midsizes. It won’t get any better honestly because Ford is back in the midsize game and Nissan is redesigning the Frontier. More competition for MPG.
I wish we could go back to the older transmissions. I never dreamed I’d see a 6 speed. Let alone a 9 speed.
Apparently a lot. Lol.
I noticed by pushing the ext pwr button, which I hope you have changed the shift points. It's a little better at shifting but you lose mpg. Best bet is to get a pedal commander
Pedal commander does nothing for shifting. All it does it tell the ECU you are using more throttle than you really are.
Isn't throttle/rpms based on your shift points?
This is why you buy the the 6 speed manual! That way you only want gear when you want [emoji1612]
Don't get too warm & fuzzy over the 6 spd, it has it's own set of gremlins but yeah at least you can select the gear you want/need...
I’ve got these ones in my turdgen. View attachment 13918
