Bojangles
I’m going to look around a little bit. I like the ultragauge pretty good. I definitely want something with a dedicated display.
Does the mx 1.3 do trans temps on a 3rd gen?
It says the codes have to be updated. View attachment 14546
Ah thats good.
It took years for that 2nd gen temp to happen. Pullin teeth man.
It looks like they are on top of their game pretty good.
After all the badgering us 2nd gens did.
I forgot the issue, but i think the mx 1.2 couldnt read some pids correctly, hence the reflash to 1.3 and then some math tweaking using the scangauges xcode worked.
Remember that if u guys ever want an x gauge code on the ultragauge 1.3
Bojangles getting things done!
#BetaTesterBojangles
Clean. I like clean.Zactly
Plus car chargers have been bad for phones over the years i heard.
Even my gps wire is run thru the console into the glove box with a dedicated 12v socket hidden in it
Danks.Clean. I like clean.
Very nice. You’ll be jelly of my entertainment centerDanks.
U may like this.... ran 4 sets of wires for abs kill, and lighting and sadly the stock wiring was a jumbled mess to begin with behind the fuse panel
After pulling new wires into place
Ready to hide
Tucked... u can barely see the green and red wiring in the corners. Once the 3 plugs were connected, it looked better
Very nice. You’ll be jelly of my entertainment centerView attachment 14549
Danks.
Ready to hide
We got google image pimp slappedMan, it looks like someone intentionally got every wire and knotted them up.
And agreed with @Bojangles, it’s time to invest in some HDMI cables.
Couple years doing burg, fire alarms, cctv, residential and commercial, prewire (new construction), retrofit (existing structures).Who taught you how to braid like that? Dug?
Its not often in do that, but this was such a tight spot, it was the best route imo.
Thanks.... i pulled an extra pair of wires just in case, and theres a bit of twine thru the firewall for future pulls, and an extra 4 inches of service slack.Definitely looks great. And if anything goes south and needs worked on you already have a huge head start on tracing wiring down.
