WildlifeChick
Okay, I can see but I like the bright white because it illuminates more. I have the stock ones on a 2017 Tacoma Sport. And if anyone knows, are they easy to switch out? Thanks!!
			The color isn't going to change what's illuminated. Brighter bulbs with projectors will still illuminate pretty much the same areas but may start blinding oncoming vehicles.
Even if they’re not on bright? I switched them out on my old Tacoma and it went from that dull yellow to bright white and made a world of difference without blinding oncomers.
Haha, you’re always so thoughtful. Thanks, I was wondering why it wasn’t.?I was saving that for you, as bad as I wanted to post it.
So which is it? Above you said projector housings may start to blind people and here you say reflective housings are more likely to blind people? Also, what do you define as "long time?" OP said 2017 Sport.Reflective housing is different and more likely to blind people. Also if the bulbs were in there a long time, they can dim a bit over time.
I'm not ragging on you, I'd just like some "clarity."![]()
I agree that stock seem bright enough, for now. I just find it strange that DRL's are LED and L, H, and fogs are halogen. The contrast in color looks "off" to me. Toyota...consistently, inconsistent.Both style of housings will blind oncoming traffic with the wrong bulbs. Reflective will be worse.
She mentioned she put new bulbs on her old Tacoma, not the 17. If you see drivers with a dim bulb and a bright bulb on the road, time to replace both.
I feel that the OEM lighting is enough. Yes, I have been on unlit roads here in CA. The high beams come on then and I see just fine. Check eyes?
http://www.vleds.com/shop-products/led-headlights/h11-micro/micro-h11-h16-h8-h9.html. Simply the best Ive found
I have a 2016 Sport and changed them to the OPT 7 Boltzen AC CANBUS Series: 35w HID Kit. Using the 5000 K Bright White Bulbs. It’s a world of difference over stock halogens.
Do you think they blind oncoming traffic?
