Lift Settling: Spacer?
TheDonutAllStar
I bought a 2in OME kit in July. I took it in last week for some minor rubbing and they've indicated that the front end has settled a good bit and they want to add a 2in spacer. I'm surprised by this, as it has only been on for a couple months and I specifically got an OME kit to avoid spacers all together. What thoughts/advice to yall have?
Measure from the center hub to the bottom of the fender and check it against stock that will tell you how much lift you have.
A better question would be, was the OPs installed correctly? Mine has worked well on fire roads and two tracks, but that's all I intend to use it on. Is the OP talking about the whole front end, or just the taco lean?
