JayQQ97
MW surVivor ... clutched. 352k on the 0D0
Why is it doing that?sitting here on the pc.....seeing as I still don't get email notification on a subsciription here ....I have a shortcut to here on my wallpaper.so here I am....
I really don’t know. I’m on my cell taking a **** at my fil’s house in Carlisle pa. So I am quite limited on what I can or cannot do!!Why is it doing that?
Well that’s good. From what I saw both systems didn’t merge to promote bombo genesisWeather this morning kind of sucks, its warm, and rainy. Some areas lost power, but imo, this bomb cyclone bombed out where i'm at.
Strong for them not for us.On another note, fearless leader says the economy is still strong, and going to get even stronger under their leadership, yet jeep recently announced its shutting down its illinois plant laying off 1350 workers.
Agreed but also dries out rubber seals and gaskets if left idle in a fuel line. I try and treat every drop and run dry all my lawn an garden ****.The 10% ethanol in our fuel seems to keep a vehicles fuel system cleaner than that mtbe crap used years ago.
I know, but thats the strange issue, i have to use the 10% ethanol fuel in everything i own, but haven't had any of those issues with rubber o-rings, or gaskets. I have carbs on all my toys, and power equipment that i never drain the gas from them, yet they work fine year after year. My new holland garden tractor was built in 1971, never apart. It starts right up and runs fine when called on. I probably shouldn't use unleaded fuel in it either.Agreed but also dries out rubber seals and gaskets if left idle in a fuel line. I try and treat every drop and run dry all my lawn an garden ****.
All your luck is in your equipment. Don’t waste your money on the lottery. Lol.I know, but thats the strange issue, i have to use the 10% ethanol fuel in everything i own, but haven't had any of those issues with rubber o-rings, or gaskets. I have carbs on all my toys, and power equipment that i never drain the gas from them, yet they work fine year after year. My new holland garden tractor was built in 1971, never apart. It starts right up and runs fine when called on. I probably shouldn't use unleaded fuel in it either.
You are perpetuating a myth.Agreed but also dries out rubber seals and gaskets if left idle in a fuel line. I try and treat every drop and run dry all my lawn an garden ****.
