2008 tacoma 255,000 miles, I just had a valve job done and now I'm throwing a 420 code
Likely Causes For P0420 Trouble Code In A Toyota
A failed catalytic converter. Other less likely problems: an issue with the coolant temperature sensor, an exhaust manifold leak, a spark timing issue, leaking fuel injectors, misfires, or fuel oil contamination.
I put Seafoam in the tank today but it started running bad, losing power on acceleration, it idles very smooth. When I'm parked if i rev the throttle I hear a bunch of clattering from the Cat. I just removed the cat and a bunch of stuff fell out, kind of a ceramic looking material, couple questions is the cat shot? And any ideas on a new cat that can be shipped to California that won't break the bank?
