mrproduxn
Added these Me-so customs mirror lights today. Much brighter signals than stock and stealthy tint. Also installed the 16 RAV4 driver mirror. Around $150 total.
I do not have the BSM Blind Spot Monitor. That is why I changed to a blind spot mirror (the small convex mirror in the top left corner). Did not want to use a stick on convex mirror. The heated RAV4 mirror had the convex mirror built in.
Plug and playAwesome. I have the stick on blind spot mirrors but wish I had the installed like that.
Did the wiring connectors match up without modification?
Exact fit replacement. Side note I ordered the passenger side rav4 mirror 87931-42d50
Not my truck but this is what you see with the cap off. The 2 philips screws are exposed that hold the signal in place. The 2 wires closest to the door glass are the heater. The heat coil wires work even is wires are switched. No polarity issue. Once screws are removed the plastic pulls out enough to wiggle out the stock signal. Have to remove two wires from the slot where they are tucked in and then unplug the signal light connector. Very simple 5 minute swap. Maybe 7 minutes if you install the rav4 mirror.
Finally got my 2nd rav4 mirror. Love the wide views.
