Sounds more like you need a serious front end overhaul. Ball joints, control arms, tie rods.....etc.
Shocks typically don't cause wobble. Unbalanced wheel cause vibration, not wobble. Worn front suspension parts are prime candidates to cause wobble.
You are driving a Gen 1 with a significant number of miles. Parts will wear out to get loose causing wobble.
Suggest to visit a shop that specializes in front suspension. Have them inspect and quote the work. Then make decisions. Don't fire the part cannon without a target.
My truck ended up going to a farm, but i still see it now and then no worse for wear.i don't have an issue with parts costs per se, they are not too terribly pricey when the 41 per cent off MSRP OEM holiday sales come knocking LOL
the truck maybe not worth even salvage value... and its not ready for the crusher yet
if only it had one million miles already onit...
How many years did you have it for?My truck ended up going to a farm, but i still see it now and then no worse for wear.
I'd give to them 500$ to put on new stuffs, perhaps 700$Sorry, no. I have not heard of them.
Just describe the problems you're having. Let them diagnose and give you an estimate on the repair. Once you have the estimate in hand, begin asking questions as to how they arrived at the repair and why will the repair solve the problem.
Although, just going by the shop name, I'd expect them to specialize Axles and Wheels. Their primary business could be heavy duty trucks, ie Dump, Concrete, Semi...... They may not have interest in a light duty truck. A quick phone call would confirm if they have interest.
Remember, you have 250,000+ miles on a 25 yo truck. It will likely need serious work and need big $$. As much as people believe that vehicles should last forever.........moving parts do wear out.
No way porking out over 3000$ and perhaps as much as 5000$
the New MT clutch needed sooner or later I am most happy to pork out 1700$ for which has been budgeted for in advance
Problem becomes when one has some much already invested in repair work they can't stop, or don't know when to. I've seen it happen. You just have to tell yourself its time to bite the bullet, and send it down the road.One day you will need to determine if the repair cost exceeds the value of the truck.
The value of the truck is more than just money based. The value determination should include the Use, insurance, replacement and a host of other intangibles.
When repair costs exceed the value, then you have crossed the line to throw good money after bad.
FWIW, based on that recommended repair list.....you need the front end replaced on both the left and right sides. Afterall, both sides are the same age and have the same miles.
Kinda like when you wear out a pair of shoes. Typically, one shoe is more worn than the other. Who buys just one shoe?
