JayQQ97
MW surVivor ... clutched. 352k on the 0D0
What sort of psi is best to use?Nice
Yes I have
I was pumping in 120psi
Yes I have
Disappointed... thing is those those Monroe quickstruts turned out tobe absolute junk on my rig... Unless something else in great need of repair that the inspector experts never seem to get a good eye on if it is a needed suspension steering repairDe struts are butefull.
They were fine on my gen1 tundra. What did you not like with them? When i bought them from a local auto parts store, they asked me which ones models i preferred. They said monroe offers a less expensive grade, and one that is more of a beefier grade, and a longer warranty. I took their more expensive ones. They performed identical to the kyb's that i removed.Disappointed... thing is those those Monroe quickstruts turned out tobe absolute junk on my rig... Unless something else in great need of repair that the inspector experts never seem to get a good eye on if it is a needed suspension steering repair
So onto the next repair before I have to pork out big coin (over $1000 is likely) so I that I can safely wheel more than 5mph on a rugged outer cemetery road
Yikes!
It's likely I'm very frustrated because everything non-routine seems to be needing done all at once one right after the other not much for downtime between the routine stuffsI hear you. I still have a few regrets selling the tundra, it had a wider bed which i really miss. At least its still running as a farm truck in the next town over with its new owner. I could i put it out to pasture.
Indie Toyota shop did a rough estimate for those cab mountsYes. All. Take a look at the engine mounts. Don't forget the bushings and mounts for all the suspension. Ball joints, lower control arm mounts.......
Rubber from '97 can easily be degraded.
i am searching the YouTube to see whats involved for the DIYSeems rich to me......
I think you can do this yourself. It may take some jigglin' around to wrangle each cab mount out for replacement. Probably able to "lift" one side (ie driver's side) at a time to work that side, then do the other side.
Only need to lift enough to support the load off the mounts. Shouldn't need to remove the cab.
Remember, shops run on standardized labor hours. They probably are looking at a book for the cab removal/install procedure and the associated hours.
Before you do anything. You should confirm the mounts are good or bad.
